I was looking for Astra plugs at the two local parts places I use and got a hit only on the Autoline products, the 5224.
Well, that seemed odd, so I dug into the cross reference and it seems there are a LOT of options from all the brands for a lot of different vehicles. Some of these plugs the stores have, but don't list. Kind of wierd, not what I am used to.
http://www.autolitecatalog.com/PartDetailWindow.aspx?b=A&pn=XP5224
So, does anyone have any suggestions for the Ecotec 1.8 VVT? I have the Autolite Ir ordered, but I suspect they are not the best. I suppose these are all different heat ranges..?
Heat Range Chart Location G11
Hex 5/8"
Reach 3/4"
Resistor/Non-Resistor/Suppressor Suppressor
Seat Gasket
Thread Diameter 14MM
Tip Special Power
Competitors
BOSCH 4312
BOSCH 4419
BOSCH 4512
BOSCH FGR9DDP
BOSCH FGR9DPQ
BOSCH FGR9DQI
BOSCH FR7KPP332
CHAMPION 9002
CHAMPION 9202
CHAMPION 9203
DENSO 3377
DENSO 3396
DENSO SK20DR-M11
DENSO SK22PR-M11S
DENSO SKJ16CR-L11
DENSO SKJ16DR-M11
DENSO SKJ20BR-M11
DENSO SKJ20DR-M11
DENSO SKJ20DR-M11S
DENSO SKJ20DR-M13
NGK 2477
NGK 3657
NGK 4080
NGK 4095
NGK 4757
NGK 5114
NGK 5887
NGK 5899
NGK 6441
NGK 6737
NGK 6994
NGK 7743
NGK 7746
NGK IFR7G-11K
NGK IFR7G-11KS
NGK IFR7L11
NGK IZFR5B
NGK IZFR5G
NGK IZFR5J
NGK IZFR5K
NGK IZFR5K11
NGK IZFR5L-11
NGK IZFR6F11
NGK IZFR6H-11
NGK IZFR6K
NGK IZFR6K-11
NGK IZFR6K-11S
NGK IZFR6K-13
NGK IZFR6N-E
NGK PZFR5J-11
NGK PZFR5Q-11
NGK ZFR5FIX-11
NGK ZFR6FIX-11
Hex 5/8"
Reach 3/4"
Seat Gasket
Tip Special Power
Competitors
BOSCH 4312
BOSCH 4419
BOSCH 4512
BOSCH FGR9DDP
BOSCH FGR9DPQ
BOSCH FGR9DQI
BOSCH FR7KPP332
CHAMPION 9002
CHAMPION 9202
CHAMPION 9203
DENSO 3377
DENSO 3396
DENSO SK20DR-M11
DENSO SK22PR-M11S
DENSO SKJ16CR-L11
DENSO SKJ16DR-M11
DENSO SKJ20BR-M11
DENSO SKJ20DR-M11
DENSO SKJ20DR-M11S
DENSO SKJ20DR-M13
NGK 2477
NGK 3657
NGK 4080
NGK 4095
NGK 4757
NGK 5114
NGK 5887
NGK 5899
NGK 6441
NGK 6737
NGK 6994
NGK 7743
NGK 7746
NGK IFR7G-11K
NGK IFR7G-11KS
NGK IFR7L11
NGK IZFR5B
NGK IZFR5G
NGK IZFR5J
NGK IZFR5K
NGK IZFR5K11
NGK IZFR5L-11
NGK IZFR6F11
NGK IZFR6H-11
NGK IZFR6K
NGK IZFR6K-11
NGK IZFR6K-11S
NGK IZFR6K-13
NGK IZFR6N-E
NGK PZFR5J-11
NGK PZFR5Q-11
NGK ZFR5FIX-11
NGK ZFR6FIX-11
