What ATFs are compatible with Mercon LV?
GC/TX
My Mag Hytec pan and Suncoast external filter arrived for my F350 (5R110W)
and I would like to know what ATFs are compatible with the LV recommendation from Ford...
Is the Mercon LV syn from the factory? For some reason I believe so. And if so, I suppose I would just go with whatever is least expensive on the market.
I have found out that AMSoil makes one as does Mobil 1. Does anyone know if D4 from Redline is compatible?
Thanks
Originally Posted By: Onmo'Eegusee
Best bet would be to call Redline. I think D6 would be a closer match, though.
Ah probably since it states it is for the Mercon SP, which I believe was replaced by the LV.
The Amsoil low viscosity fluid is compatible.http://www.amsoil.com/catalog.aspx?code=ATLQT-EA
Guys/gals, yes I am aware AMSoil is compatible... stated that in my first post.
Asking WHAT ELSE is that is on the market. This way I can price out other products and purchase the best for the least price.
Originally Posted By: Eddie
The words compatable and suitable is scary if you look up the meaning.
Definitely agree.^
