Consider a owner-operated wheel alignment shop that uses mechanical gauges and strings to do alignments vs a chain that uses a computerized laser alignment machine. Which would you prefer?
Some people don't even know that alignments can be done without a computerized machine.
My feeling is that if I wanted the alignment simply measured, the computerized machine operated by employees of unknown experience might give a better report. However if I want the alignment adjusted, I suspect would be better off with that owner-operated small shop that uses gauges and strings.
Opinions?
Opinions?
