#1, the vast majority of alternators are temperature-compensated and cut back on output voltage as they heat up. Ohm's law tells us that lowering the output voltage of the alternator reduces the amount of current drawn out of it.
#2, the regulator in most alternators, certainly anything you'd find in a car, is NOT a linear regulator.
#3, the alternator is often bench-tested in a way that makes it produce and records it's maximum output, which often exceeds it's rated output since the test is conducted at room temperature. This does not seem to damage them.
#4, the battery on the donor vehicle will supply a significant part of the current needed to start the engine.
#5, most alternators cannot put out anywhere near their rated output at idle.
#6, diodes can be operated at higher currents for short periods of time without damage. The limitation is thermal heating of the diode. This is why heatsinking a diode allows it to handle more current.
Quote:
Maximum (average) forward current = IF(AV), the maximum average amount of current the diode is able to conduct in forward bias mode. This is fundamentally a thermal limitation: how much heat can the PN junction handle, given that dissipation power is equal to current (I) multiplied by voltage (V or E) and forward voltage is dependent upon both current and junction temperature. Ideally, this figure would be infinite.
Maximum (peak or surge) forward current = IFSM or if(surge), the maximum peak amount of current the diode is able to conduct in forward bias mode. Again, this rating is limited by the diode junction's thermal capacity, and is usually much higher than the average current rating due to thermal inertia (the fact that it takes a finite amount of time for the diode to reach maximum temperature for a given current). Ideally, this figure would be infinite.
Maximum total dissipation = PD, the amount of power (in watts) allowable for the diode to dissipate, given the dissipation (P=IE) of diode current multiplied by diode voltage drop, and also the dissipation (P=I2R) of diode current squared multiplied by bulk resistance. Fundamentally limited by the diode's thermal capacity (ability to tolerate high temperatures).
Operating junction temperature = TJ, the maximum allowable temperature for the diode's PN junction, usually given in degrees Celsius (oC). Heat is the “Achilles' heel” of semiconductor devices: they must be kept cool to function properly and give long service life.
