Originally Posted By: BigJohn
Originally Posted By: Familyguy
I wouldn't worry about using up the last of your RP. If it was my car (I've owned a number of Audis), I'd use Rotella 5W-40 full synthetic and stick with whatever the manual states as oil change intervals until it's out of warranty. Once it is out of warranty, I'd likely revert to my usual 7500 mile OCI.
Also, in case you didn't know, a simple chip swap can goose the 2.0T up to 240-250hp. zoom zoom
Best,
I have asked the question a couple of times without a solid answer.....but will Rotella T6 damage the emissions in a Audi or VW with the 2.0T?
Also, I might be interested in the chip swap. Who can install one and what do they cost?
There is no "chip swap" on a 2.0T, the ECU is direct-programmed. You can run a stage 1 program without further modifications. You'll also typically find that your fuel economy
improves, along with the power boost. Here are a few providers to take a look at...
http://www.goapr.com/
http://www.giacusa.com/
http://revotechnik.com/
http://www.unitronic.ca/
What kind of power you'll see depends on which 2.0T variant you have. Do you have an FSI or TSI engine?
