When I last changed the oil in my car I opened up a 5 quart jug of Mobil 1 to use as the new oil. And as you Mobil 1 consumers know, there's an aluminum sticker type thing on the bottle opening to show that the jug has never been tampered with.
Of all the times that I've changed my own oil, this has never happened before but at that one time, I punched a hole through the sticker with my thumb, and some of it tore off and fell into the oil.
Then I tried to pull it out by pouring the oil into another jug with a mesh screen on top of the funnel. After pouring out about 2 quarts, nothing came out so I thought the sticker was stuck to the very bottom.
After this failed attempt, I proceeded to fill the crankcase with the mesh screen. All 4 quarts were poured out and there were still no signs of that sticker.
And today I had to top it off, so I got that same jug and used no screen because I'd completely forgotten about that sticker. When I was pouring away I saw a clump going into the oil filler neck and I immediately remembered what that was.
I guess the good news is I haven't started the car yet.
Would it just stay put on the bottom of the oil pan, knowing it's tendency to stick to the bottom? Will the oil filter catch it? What should I do?
--cliffnotes--
The aluminum sticker that comes on new jugs of oil fell into my engine. Car hasn't been cranked since then. Is there anything I can do?
--cliffnotes--
