How many people useing it have a real time reading oil pressure gage. If you gage does not move around significantly with RPM and even flutter at idle then you probably do not have a real time oil pressure gage. Most vechiles that have them are driven by the ECM/PCM epending on Make and as long as the oil pressure is in an acceptable range the needle stays put in the same place all the time. This is what most like me call idiot gages.....They only move if the reading is higher or lower then the average acceptable range as programed into the computer so they look like a real gage but function like an idiot light.
Like wise if you see no difference between a 15W40 and a 5W20 on the gage then it is not reading the signal at the sender and reporting it real time since these hot or cold should produce huge difference in behavior and reading.
No fast forward to MMO 1 quart of that stuff is going to thin the heck out of the oil. You have to expect an impact in hot and cold oilpressure as that is just the way things work no free ride. Now the question is how much is it affecting your application?
No idiot lights as thsestellus nothing unless your came on. Many of them are set so insanely low that it not comeing on would not be telling us much.
Anyone else have a Buick 3800 to try 1 quart of MMO in? Obviously you have to have a factory oil pressure gage to compare to my number's!
