I have a newer olivia LCD 37 inch television, it uses around 80 watts.
My 10 year old Zenith 19 inch CRT television uses about the same.
So there are a few watts to be saved, but it isn't as much as you would think.
The only ones that use huge wattage is the old big screen cabinet type televisions.
Also plasmas use a ton of wattage.
