dmcnelly
Thread starter
Originally Posted By: Silver02ex
When i had amy SL2 i used whatever cheap 5w30 at 3K OCI, and a Supertech 3614 filter. Even after replacing the valve cover gasket, it still used up about 1qt in 1K miles. I don't see a point using Mobil one or K&N filter.
That's because you had an oil consumption problem, most likely bad piston rings. I don't have that issue, so there is a point in my instance.
