Originally Posted By: Bluestream
Chains are a must, wheel weight I found do nothing.
I would get a blower if you can, works much better than a plow
This is your best advice, my friend......
I had a farmette in middle Maryland for 20+ years. It had a longish drive and a parking pad. I also had horses and need to clear a path to the stables, the loafing shed and a 'highway' to the muckings pile. A blade just doesn't gitter' done....
You can push about 2-3" of snow with it but once you start getting it about blade high in your 'disposal' pile you are flat up a creek... chains, wheel weights, silicone spray, PAM and wax on the blade don't do squat. My 18hp Sears w/ blade probably topped 500lbs and it was no match for piled or deep snow. I eventually bought the snow thrower attachment for it.
The snow thrower would take the the heaviest, deepest snow and toss it about 25'- 40' at full power getting it well clear of the driveway. True enough, you had to put her in Granny-Low gear but it would chew its way through deep snow and drifts higher than the tractor hood like a termite going through balsa wood.
The only disadvantage to the tractor blower set up is this.... because of their weight they don't do hills and grades very well as most of the weight is up front. Get'm sideways, or on a steepish grade, or in a rut and you have a 700 lb boat anchor. (Yes, I'll admit to having to tow mine out of the pasture a couple times with my Wrangler until I got the hang of operating it.) Also, if they don't have a 'locker' differential you just like a car... one wheel spinning and the one with traction looking at you.
The second thing is that the tractor blade/blower set ups are long and wide .... and that's a problem trying to maneuver in tight places. I'd have to 'back and fill' a large space to be able to turn around. Third, although they can take a full width cut (I think mine was 42")you really don't want to do about 20, or less, in really heavy snow. Fourth, the belt drives are great and the work like a champ... but they have a habit of breaking in 20F weather in deep snow. They are a b@a$t@rd to replace when you're laying on your back with snow and water running down your neck and your hands are frozen....
But,I used this set up every winter to do my place and my neighbor's farmettes for 20 years. I finally had to replace it.
NOW...
if you want a hot tip... considering all the money you are going to blow on wheel weights, blade, chains, etc., etc.... I'd hop down to the Ariens dealer (Home Depot!) and get a snow thrower... spring in the 110V electric starter and heated hand grips ...
http://www.ariens.com/products_snow/s_deluxe_platinum_group/s_deluxe_platinum_30/Pages/default.aspx
This is really the ticket as it's much more maneuverable, gets into small spaces (you can even do between the cars)and stores in a small space. (And you will never go hungry!!! The neighbor ladies will be delighted to ply you with brownies, cookies, hot chocholate, toddies, or what ever!!)
