I'm getting a small draw on my battery with my car off. If I remove the negative battery lead and put a multimeter on the positive terminal and the block I get a small draw that starts of at around 200 mV and slowly decreases to about 10 mV and then stays there as far as I can tell (I had to replace my PAS pump this weekend so I only had an hour or so to fiddle with this). I pulled every relay and fuse one at a time and nothing affected the draw. The 10 or so grounds that I checked seemed tight but I did not get to them all. This is a brand new duralast gold battery. Any helpful hints on where to go next?
I have heard that a diode can go bad in the alternator and cause it to draw off the battery but I would have expected the draw to disappear when I pulled the alternator fuse.
