The more metal, the more condensation surface. Longer duration before the system heats up, therefore a bigger mass of water is just in there.
Add in low-temp use, lots of idling, and relatively low flow for long times, and youre more prone to build up lots of water.
There is also the issue of combustion efficiency, fuel rates, and how much water is made. A big engine is likely to move more air/fuel at idle, and thus have more water there, then more buildup in a big system.
Condensation in the system aside, it also likely has much to do with how cold you are before coming out to the atmosphere, and then how it disperses.
