Turbos need a different system.
But sure, in any case, who would want that sludgy stuff collecting in the manifold, on the throttle body, on the valves, and in the combustion chamber?
Even when the car is off, heat soak will collect and deposit vapors all over. We want to attenuate that.
Do your homework and get a suitable system .
Why don't factories do this?
They can't put a system on that requires such high maintenance.
You will have to dump the residue out of the 'can' a lot.
