ATP At-216 Synthetic atf
by RdSnake
04/23/18 12:25 PM
Mann-Filter HU 711/51 X (cartridge) C&P
by 1JZ_E46
04/23/18 12:24 PM
Pennzoil Warranty
by Isophix
04/23/18 12:08 PM
buying oil.. question
by Dymblos
04/23/18 11:40 AM
Recommend me a UV light for AC dye leak detection
by zzyzzx
04/23/18 11:32 AM
2004 Toyota Sienna overheating
by Rtstrider
04/23/18 11:29 AM
Milesyn SB 10W30 API GF-5/SN, Synthetic Blend ?
by Quickman28
04/23/18 11:28 AM
Looking at a Hybrids as the main Family Hauler
by FutureDoc
04/23/18 10:54 AM
naturally aspirated cars left?
by flinter
04/23/18 10:31 AM
1989 Mercedes 300E
by jxthomps
04/23/18 10:07 AM
Just what we need, another Redline 5w30 VOA
by UG_Passat
04/23/18 09:54 AM
Electric Pressure Washer Recomendations
by Egg_Head
04/23/18 09:50 AM
VW Jetta 5 cylinder cartridge oil filter
by troyken
04/23/18 09:48 AM
Mailing in to Blackstone?
by 07titan
04/23/18 09:43 AM
Cameras With Film
by BlueOvalFitter
04/23/18 09:29 AM
Dipstick Tube on 4.6L
by Ifixyawata
04/23/18 08:48 AM
Starting Issues
by coopns
04/23/18 08:48 AM
3D pistons
by supton
04/23/18 08:39 AM
Replaced the high pressure fuel pump on my GTI
by skyactiv
04/23/18 08:08 AM
Fumoto is IN
by Kira
04/23/18 07:59 AM
BradPeterson, daylateetc, Kjammer, sonnyk, PWMDMD
64821 Registered Users
83 registered (askani79705, 1WildPig, ArrestMeRedZ, AZjeff, Bandito440, Balrog006, 8 invisible), 1794 Guests and 39 Spiders online.
64821 Members
68 Forums
282190 Topics
Page 1 of 2 1 2 >
#1693201 - 12/02/09 10:06 PM 10w-30 trans oil
sdan27 Offline
Loc: Michigan
We have a pair of Case front end loaders that both call for 10w-30 engine oil for the transmission. Should the engine oil meet any specific API classifications or doesn't it really matter for a trans. They are both ZF powershift tranmissions with 4 speeds. In the past, we've just used whatever they have at Napa which is oil rated for gas engines.
'94 F250 Powerstroke. LF9691 primary oil. AH1141 air filter. FS1282, FF5320 fuel filter. WF2071 coolant filter.
#1693216 - 12/02/09 10:17 PM Re: 10w-30 trans oil [Re: sdan27]
Steve S Offline
Loc: East of IGO
I used to work for a Forklift dealership and some forklifts did indeed use a 10w-30 motor oil . Use HDEO oil which is a far superior oil as compared to a passenger car motor oil.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#1693310 - 12/02/09 11:52 PM Re: 10w-30 trans oil [Re: Steve S]
Audi Junkie Offline
Loc: PA
Consider Syncromesh. It's made specificly for MTFs that spec motor oil.
2008 Opel Astra 1.8 VVT 5M
2010 VW Tiguan 2.0 TSI 6M
(APR Powered)
#1693963 - 12/03/09 02:17 PM Re: 10w-30 trans oil [Re: Audi Junkie]
Steve S Offline
Loc: East of IGO
I forgot to add that if you look up the specs on oil they should list a the trans approval number . Like gl3 for example, it has been awhile.
#1694037 - 12/03/09 03:32 PM Re: 10w-30 trans oil [Re: sdan27]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
sdan27 - Year and model of Case and ZF type would help in providing you with advice
Regards
Doug
#1694134 - 12/03/09 05:25 PM Re: 10w-30 trans oil [Re: Doug Hillary]
sdan27 Offline
Loc: Michigan
I'm not sure on years or trans model but the one loader is an 821 and the other is an 821C. Usually I get one of the loaders in the shop to service it and see it's due for a trans oil change and just do it without any planning ahead. Will have to make a point to try and keep some HD 10w-30 on hand. We also have a Case 450 skid-steer and a Cat Challenger MT765B that call for 10w-30 for hydraulic oil. I'd imagine I should use the same HD oil in those as well?
#1694188 - 12/03/09 06:14 PM Re: 10w-30 trans oil [Re: sdan27]
Hi,
you should use a conventional 10W-30 lubricant as specified
Commonality with engines as a 10W-30 HDEO is not a bad idea of course
Castrol do/did make a specific lubricant "TFC410" which met ZF TE-ML 03, 04, 06 and 14 in an appropriate viscosity - this may not be available in NA
IMO it is always wise to follow the Manufacturer's specified fluids - especially in the case of ZF for instance
Regards
Doug
#1694322 - 12/03/09 07:28 PM Re: 10w-30 trans oil [Re: Doug Hillary]
sdan27 Offline
Loc: Michigan
I think I'm going to have to find some literature for our loaders and figure out what those specs are. Thanks for the advice.
#1712594 - 12/18/09 09:27 PM Re: 10w-30 trans oil [Re: sdan27]
sdan27 Offline
Loc: Michigan
I got a operator's manual off ebay and I guess the trans is supposed to use 15w-40 engine oil instead of 10w-30. The crazy thing is, I talked to a couple Case techs that said that it was supposed to take 10w-30. Hope I didn't cause too much damage. We are having some issues with that same loader right now that it doesn't want to move very well but I'm hoping it might be unrelated.
#1713250 - 12/19/09 05:28 PM Re: 10w-30 trans oil [Re: sdan27]
Steve S Offline
Loc: East of IGO
I doubt there is any damage done .
#1764337 - 02/01/10 02:09 PM Re: 10w-30 trans oil [Re: Steve S]
sdan27 Offline
Loc: Michigan
When I was saying that the loader quit moving on us, turns out the trans had a complete failure. Had nothing to do with the oil we were using in it though . Inside the trans, the output tube from the charge pump to the valve body and torque converter cracked so none of the oil was getting to where it should be and all the clutches and everything got burned up in it. Had it sent out to a shop and should be getting it back anytime.
#1764912 - 02/01/10 09:15 PM Re: 10w-30 trans oil [Re: sdan27]
Steve S Offline
Loc: East of IGO
Thanks for the update, probably an expensive repair.
#1764918 - 02/01/10 09:18 PM Re: 10w-30 trans oil [Re: Steve S]
sdan27 Offline
Loc: Michigan
A little less than $14,000 for the trans and torque converter rebuild.
#1767472 - 02/03/10 07:17 PM Re: 10w-30 trans oil [Re: sdan27]
Steve S Offline
Loc: East of IGO
Industrial repairs are pricy.
#1771028 - 02/06/10 01:11 PM Re: 10w-30 trans oil [Re: Steve S]
onion Offline
Loc: kansastan
Those transmissions originally came from the factory filled with Case HyTran hydraulic oil. At some point- roughly 2000-2001, Case and/or ZF changed their mind, and decided that these machines (621,721,821, B, C) should use 15W40 in the transmissions. Not sure what the reasoning was, but I did swap the fluid in several of them. Seeings how the viscosity of 10w30 will generally fall somewhere between that of hydraulic oil and 15w40... I wouldn't worry about it too much.
I do that know some of the bigger Allison transmissions can use either DexIII or 15W40, depending on temperature range and application. I've been told (haven't seen it in writing, though) that the transmissions produce less heat when running on 15w40 due to less slippage in the torque converter.
The invisible and the imaginary look exactly the same.
Page 1 of 2 1 2 >
