I have a blazer that has a tendency to get plugged up injectors after a few years. GM has a updated fuel spider that changes the system to MFI. My question is how often should you run fuel injector cleaner. Would it hurt to run it every other fill up? Is once an oil change good enough. I generally never use additives so im not real sure here. Can you run the stuff too much?
