Hi guys. Long time reader, first time poster.
I've got to do an oil change on my BMW 535i (the one mentioned in my signature) and I currently run Castrol Edge 10W60, and the factory sticker under my hood specifies 10W60 oil be used in this car.
I was at the auto parts shop on the weekend, and while reaching for the Castrol 10W60, I spotted some bottles of Penrite 10W70 (Penrite is a local Aussie company here, you may not have it in the US). I thought about using it, for three reasons:
1. the 10W "cold" number would be good on cold starts, as this would be thin enough to allow quick circulation around the engine when it first starts up?
2. The 70 viscosity number would be good because BMW V8s have a very high "normal" operating coolant temperature of 110 degrees C, and these engines always run *very* hot, even from factory. If the oil only thinned down as much as a 70 viscosity oil when hot, then this would be good because it would still provide a good thick lubrication film and would not thin out as much under the high temps. Plus, there are no oil coolers in the car at all, so the oil has to just suffer the high heat.
3. This engine has covered 250,000 kilometres and it is 13 years old and never rebuilt. Tolerances between internal parts are probably worn larger than they were 13 years ago. So maybe using a slightly thicker oil would help boost oil pressure and be better for the engine, considering how much wear there probably is inside it?
Are my three points above correct? Or is my logic wrong or am I missing something very important in my considerations about using this oil? I can get no help from the BMW community, because they believe that they must stick to what is written in their owners manuals, and never change viscosity. But my car has travelled double the amount of mileage theirs has. I am being told by owners to put really thin oil in the engine (10W40, 0W30) because thats what everyone else uses. But in an old engine like mine, I think a superthin oil would be a bad thing?
Oh, some info about my situation-
*I drive my car fairly hard. I'm no grandpa.
*I have never had any mechanical problems with the engine. Always smooth and always reliable.
*My driving consists of 50% city stop/go and 50% highway every day.
*We are just coming into summer here, and the temps are already getting high outside (100F/40C so far)
*I love my beemer and I want to make sure the oil I use will contribute to further longevity of my engine. Even if that means changing viscosity as it gets older, to compensate for wear & tear.
Can you please give me some feedback?
Here is the webpage for the Penrite oil in question: http://www.penriteoil.com.au/products/motor-oil/sin/sin_engine_oil_10
And they seem to have a very well written FAQ page as well, which was suprising:
http://www.penriteoil.com.au/faq.php
Thanks guys
Thanks guys
