Blackstone Labs
For an oil run nearly 16,000 miles wear looks great! Universal averages for the 3.2L are based on
an oil run of just 8,000 miles. We found a trace of fuel in the sample, which caused the low viscosity but
other than that everything looks good. Neither the fuel nor the low vis is a problem. The TBN read 1.8 so
you had some, but not much, active additive remaining. We consider 1.0 too low for extended use. Feel
free to run the next oil 17,000 miles. Check back for another look when you have the oil changed. You
may be able to go longer yet.
Miles on unit-105,700
Miles on oil -15,700
01 Mercedes SLK 320
Make-up oil -1 qt
Capacity - 8.5 qt
Amsoil 5w-40 European Formula
Sample Date 6-02-08
ALUMINUM-7
CHROMIUM-0
IRON-27
COPPER-4
LEAD-2
TIN-0
MANGANESE-1
MOLYBDENUM-7
NICKEL-1
SILVER-0
TITANIUM-0
POTASSIUM-1
BORON-45
SILICON-9
SODIUM-17
CALCIUM-1328
MAGNESIUM-128
PHOSPHORUS-754
ZINC-963
BARIUM-0
cSt Viscosity @ 100°C---61.1
SUS Viscosity @ 210°F----10.53
Flashpoint in °F---375
Fuel %---TR
Antifreeze %---0.0
Water %---0.0
Insolubles %---0.3
TBN----1.8
TAN
ISO Code
01 Mercedes SLK 320
Make-up oil -1 qt
Capacity - 8.5 qt
Sample Date 6-02-08
ALUMINUM-7
CHROMIUM-0
IRON-27
COPPER-4
LEAD-2
TIN-0
MANGANESE-1
MOLYBDENUM-7
NICKEL-1
SILVER-0
TITANIUM-0
POTASSIUM-1
BORON-45
SILICON-9
SODIUM-17
CALCIUM-1328
MAGNESIUM-128
PHOSPHORUS-754
ZINC-963
BARIUM-0
Fuel %---TR
Antifreeze %---0.0
Water %---0.0
Insolubles %---0.3
TBN----1.8
TAN
ISO Code
