I have a trailer that has a spare flat mounted on the drawbar. when it rains it keeps about 1/2 inch of water sitting in the rim which i think will lead to corrosion.
I am thinking of drilling 4x 4mm holes in the low part of the rim to let the water drain. i might also smear some grease on the bead between the tyre and the rim cos i have seen some serious rust develop there where water pools.
the rims have a load capacity of about 700kg, they only need about 375kg . many rims have many holes in their support structure no worries. Is it OK???
Shannow/Sprint these are the ex falcon ROH steel rims they re-fit to trailers and caravans.
i don't want to buy a tyre cover as A) don't want to waste money and (B) it will make it nice and stuffy for corrosion and critters.
http://www.roh.com.au/steelwheels.php the rims are the "caravan" type and the little drain holes will be equispaced on the "donut" bit of the profile about halfway between the hub and tyre.
