In the on-going saga with the 2002 Sienna and tires, last week I had my van in the shop for the timing belt and re-visiting the vibration issue.
They thought they found one bad tire, so they mounted the spare. Drove to Columbia, MO from our home and had one bout of the vibration again. Pulled over, nothing obvious and never saw it again the remainder of the day.
However, I woke up yesterday to look at the age of the tires and that's when I noticed that the wrong size tires were on the van.
The van had P205/65R15's on it, and the factory size is P215/65R15. So, I bought new tires yesterday and had them give me the old ones.
I took them home and examined the tires inside and out. That's when I noticed the liners of two of them were cut, cracked on a splice. The cut is near the shoulder of the tire.
The cut seems to follow the splice as it appears to go nearly perpendicular to the direction of travel. One has about a 1.25" cut inside and the second has a mere 0.5" cut.
Has anyone seen such a thing?
Could this cause balance/vibration issues that would be difficult to diagnose.
The van really feels like a new vehicle with its new tires, so we'll see if this does it.
Comments?
Comments?
