Hardware_Monk
Thread starter
Thanks again for more background on these motors.
I've become aware that the newly introduced synthetic may be causing the engine to shed deposits. Its one reason I have tried several oils in short order in the Maxx, my most recent problem vehicle.
With this possibility in mind, and the upcoming cold weather, I believe I will immediately try the 0W-30 that was recommended by il_signore97 and seconded in principle by wolfc70. I have noticed other references to the 0W-30 and 0W-40 in the forum, but had no feel as to their usefulness.
If the 3.5 in the Maxx does not quiet down during hot operation, I will switch it to 0W-40.
I believe that if this oil type works for my Venture 3.4, the 0W-30 will be enough. It is noisier when cold, but quieter when warm, than the 3.5 in the Maxx. Apparently I'm also lucky that its not an oil burner...
I will check with a local dealer to see if they can find any record of a warranty repair on the 3.4 intake gaskets.
Meanwhile, once I find an oil to stick with, I'll have a UOA done for both engines. In the case of the 3.4, this could warn me of slow coolant leakage into the oil(?).
Had I known how different these newer engines would be, my approach would have been very different. I may never have made significant changes in oil type(as several earlier posts thought would have been wiser), or I would have done so in stages.
Once trouble started, I knew I needed to find an answer fast, so I am very grateful that so many helped sketch out where I was at.
Thank you all very much!
