Okay, lately, most gas nearby stations have switched to a 10% ethanol mix, but whenever I fill up my Volvo 850 with that, the check engine light comes on almost immediately. The dealer read the codes and said it is an intermittent knock sensor code.
However, when I travel out of the area and fill up on other brands of gas, notably Shell, the light goes off completely. As soon as I put an ethanol mix in, the light returns.
I wouldn't worry much, except that the car also starts harder (cranks a while), runs rougher, and my MPG goes from about 28 on non-ethanol, to about 23 with ethanol in the mix. I don't entirely blame the fuel, but I suspect the car is somehow just having trouble burning it as efficiently. My cavalier gets a very slight decrease in mileage as well (3-4%), but runs equally well on either.
Does anyone know how to solve this problem? The dealer is suggesting a new knock sensor. Will that really fix it, or just get rid of the check engine light? I want my car to run smooth again and get the mileage it should.
What gas is available in NY with less or no ethanol? I normally use Sunoco, Hess, and BJ's, which all have the 10% sign on their pumps here. There are NOCO, Kwik Fill, Mobil, Valero, and Gulf stations nearby that I haven't checked out. Any suggestions?
Thanks!
Thanks!
