Got a remanufactured motor, about to install it actually right now, working on it as we speak. (some of you have seen my other thread about the project, and thanks for the help over there as well!) Project is behind schedule but I've hit a snag - the gasket set that came with the engine, included an intake manifold gasket that has the rear ports on the gasket blocked off with a little metal piece within the gasket. My actual cylinder head, and intake manifold (both stock) have holes in that location. The Haynes Manual says that "some models have the rear passages blocked off" and to make sure the gasket is installed that way on those models to ensure proper amount of coolant flow, but it does not specify which models this pertains to. From what I can tell, the intake would get coolant flowing through it either way, from the thermostat to the rear of the intake where the screw-in fitting is that goes to the heater core. What I want to be sure of, is that if I leave that passage blocked off by the gasket, if I am starving the cylinder head itself of coolant. I do not remember if the original motor I took out of the vehicle had this blocked off or not. There are coolant passages in the front of each cylinder head that mate up to the intake, I just can't figure out how else the cylinder head would get coolant flowing through it all the way to the rear of the cylinder heads without this hole open, but I admit I do not know much about these cylinder heads, or if they have some sort of other passages in them that line up with coolant passages in the block that would still specifically feed them in such a manner to allow flow all the way through them, with these rear gasket holes blocked off.
Can anyone help, with a definite answer? Would hate to mess up the motor, or have to do this twice.
Thanks in advance!!
Thanks in advance!!
