I've got some gas in the oil of my ATV('01 Suzuki KingQuad 300), it has a carb and is probably running slightly rich on idle as I don't have to use the choke to start it cold until the air temperature gets down into the low 50's. Is any smellable amount to much gas in the oil? Or is some to be expected on a carb'd ATV?
The oil has been in for a year with maybe 100 hours (half of those working hard plowing) and looks decent and I was thinking of leaving it for the winter atleast as its RTS 0W40. I plow with it and the oil cooler gets above 212F atleast, as snow will boil off it quite quickly... Should the gas in the oil evaporate quickly with a couple hours of high oil temps or will it take longer than that?
The safe route is to change it but at $30 a pop I thought I'd ask first!
