You see a number of posts about how well Briggs small engines hold up, so I thought I'd detail the saga of one of my Tecumsehs.
I bought the mower at Target on clearance for $70.00 in the fall of 1997.
It is a 21" MTD Lawnflight, with a Tecumseh of, I think, 4.5 bhp.
The Tecumseh has never had its oil changed and only got its second plug two weeks ago. The original Champion was pretty well destroyed, to the extent that the thing would barely run.
I used the mower almost exclusively on my large yard for ten years, 1998 through 2007. In the spring of 2008, on the first cut of the year, the blade had about 1" of its tip fail and break. This caused the mower to vibrate noticeably. I finished mowing the lawn, about another fifteen minutes run time.
Oil had leaked out underneath, from the crankshaft bushing, as a result of the imbalance. I parked the old thing, and used my other mower for the rest of 2008, and for 2009 until a couple of weeks ago.
I bought a new 21" blade, along with an air filter and a couple of other things, from AA, using the $10.00 coupon.
I installed the new blade, and used ether spray to bring the old thing to life.
It idled well, but died under load.
I removed the plug(for the first time), and cleaned it. The center electrode was pretty well gone, to the extent that the porcelin surrounding the center elcerode had been erroded. I cleaned the plug, put it back in, and finished the lawn.
I bought a new plug last week (Autolite), installed it yesterday, and cut the lawn.
The mower ran strongly, with no leaks from the crank bushing.
I am estimating that this engine has run about 400 hours.
I have never changed the oil on purpose.
The machine was very cheap, and I wondered how long it might go with mere topping off.
I guess it will go for quite some time, although oil consumption is now around 3 oz/hour.
I am in awe of how durable these cheap engines are!
