I believe Nissan refers to this product as "Ester Oil" because it contains some ester, as opposed to it being "ester based".
Originally Posted By: gizzsdad
I found some interesting info in the first post of this thread:
http://forums.maxima.org/7th-generation-maxima-2009/594149-why-special-oil-09-maxima.html
The information in the above link states:
"It is seen that the friction coefficient declined as the hydrogen content of the DLC coating was reduced, with the lowest value being displayed by the hydrogen-free DLC coating (a-C coating). That result is attributed to the suppression of metal contact at the sliding surface owing to accelerated adsorption by the a-C coating of oiliness agents in the engine oil. Since the engine oil used in this evaluation contained many additives besides the oiliness agents, an investigation was made of the potential friction reduction obtainable with a combination of the a-C coating and oiliness agents. For that purpose, 1 wt% of glycerin-mono-oleate (GMO) was added to a synthetic poly-alphaolefin (PAO) oil as an oiliness agent to produce a prototype oil for use in conducting a POD evaluation. The results are shown by the dashed line in Fig. 2. The friction reduction effect became more pronounced with a lower hydrogen content and friction was reduced by as much as 75% compared with the result seen for a conventional 5W30 engine oil."
Glycerin-mono-oleate (GMO) is an ester - not a base oil, but a monoester used as a friction modifier at 1%. This may be why they refer to the product as "Ester Oil", i.e. to distinguish it from oils that do not contain this ester.
Tom NJ
Tom NJ
