Much of this is dependent upon driving style/routine.
If you've got a lot of cold starts and short trips, I'd favor a conventional dino PCMO 10w-30. Today's oils can easily handle what you'd likely put the car through. My concern for a straight 30 grade with lots of starts and cold operation is poor lubrication when cold. Pour points are meaningless (almost) for true operational considerations. The 30-grade HDEO is made for long continuous runs in heavy equipment, like diesel generators, etc. It's not intended for short trips with intermittent operation. Will it work in a pinch? Sure! But it's not optimal by any stretch of the imagination, for a small gasser engine that sees "typical" driving patterns.
If you have few starts (comparitively) and lot's of running/idling, then I guess the 30 grade would be ok.
I find it hard to believe you can't get 10w-30 HDEO. You probably won't find it on the shelf, but most places like AAP, AZ and such could order it for you (at retail cost; no sale price).
I can understand your desire to use up what you have already sitting around. I see no huge risk in using your stock up. But after that point, I'd move to a quality PCMO 5w-30 or 10w-30, or HDEO in 10w-30.
