Originally Posted By: azsynthetic
Originally Posted By: DesertDually
I've been running as a fuel supplement, synthetic WMO that has been filtered to one micron and then high speed centrifuged to one-tenth micron
Where can we get the equipments for this kind of oil reclamation?
dieselcraft makes the OC-20 centrifuge. You will still need a powerful pump to pressurize it and spin it, and a way of heating the oil to around 150 degrees in order for it to work properly. You can build a system like this if you are handy with tools and such, or you can buy a turn-key setup from a number of different vendors.
