As long as you follow the directions for a clicker (when you are done, drop the setting to the lowest value) the cheaper units from Northern tools and Harbor Freight are actually quite good. I know several guys with the HF ones and I have a Northern Tools ½” that I use at the house for setting wheel stud torque.
I also have CDI strain gauge electronic wrenches for more "precise" requirements but to be honest about it, every time that I have had my Snappy guy check them, that old NT clicker has been within 4% in the range of 50 ft-lbs up to 150 ft-lbs.
The HF guys have noticed the same thing with theirs when tested. Do not use them to break bolts loose, don't throw them around or drop them, set them to their lowest torque setting when not being used, store them in their case for protection and they will give you great service for the money.
Are they pro level tools that will hold up torquing thousands of bolts a year? No. Will they work well for a weekend warrior needing to torque a few hundred bolts a year? Yes.
If you have a 1/2 coupler, you can spot check them with a known accurate wrench between calibration checks. I check mine with one of my CDI electronics every month or so just to make sure they are close to spec.
