This last oil change I took my Fram Tough Guard filter off. I always check the oil filter surface on the block and clean it. When I checked it I found the oil filter gasket stuck on the block. This was a first for me. Maybe I have been very lucky.
I did use oil on the gasket prior to install to I am surprised by this.
How many of you guys/gals out there have found the gasket(s) stuck on the block?
