Put in a set of NGK Iridium IX today. Had to remove # 1 after torqueing it down and then reinstalled it. (Socket's rubber boot stayed on too tight and the extension came off first).
I used a torque wrench and hit the specified 15ft/lb both times.
Is it a concern that the crush washer was already crushed during the first install and probably conformed to a difference surface? Does this affect sealing?
