Originally Posted By: Popinski
seriously.. on common roads.. it's easier to pop in neutral, let it coast and use a little bit of brake to stop. Engine braking is useless and unnecessary wear.
I think people engine brake because:
A. they watch too many race car videos on youtube
B. Watched Fast and the Furious movies.
C. People just think it's cool because of the sound of the engine and exhaust.
Unless of course you are in a very hilly/mountainous roads, then it's understandable.
Oh, really, well last time I checked, the mnual transmission was in use long before video games, TV and movied were invented, and back in those days you had to rev. match on the upshifts and downshifts, so your nice little theory doesn't hold water unless you talk to some 17-year olds. These practices were developed to reduce the wear and tear on the drive train, the invention of synchronizers eliminated the need to rev. match and double clutch to an extent. It is still a good practice to double clutch and rev. match, as it puts less strain on the synchros, especially at higher RPM's.
While downshifting is not necessery, it puts zero wear on the drivtrain compared to power shifting at redline, or simply starting up the hill.
So please get your facts strait.
Maybe it was like that long ago. However, cars now don't need engine braking unless you're in a mountainous area or racing.
Every single car does engine breaking,automatics does this automatically for you(unless you force it)and with manual transmissions , you have 100% control of it.
It all boils down to degree.Now if you drive like a nut,then you have other issues.
