My wife's 09 RX350 manual and the oil filler cap specifically states 5w30. The dealer recommends 5w20, pointing to a tsb allowing it's use. The tsb says use the viscosity recommended in the manual in one paragraph, and then goes on to recommend 5w20?
Does it make a difference? I've been using PP 5w30/wix filters.
TSB:
Toyota Motor Corporation manufacturing plants have begun using ILSAC GF–4 engine oil. This engine oil is recommended due to its superiority in terms of fuel economy and engine protection and due to its benefits for both the customer and the environment.
ILSAC GF–4 can be used in all Lexus engines.
NOTE: The recommended viscosity grade for this oil differs according to vehicle model. Use the recommended grade specified on the oil filler cap or in the Repair Manual or Owner’s Manual for each vehicle.
Applicable 2006 model year Lexus vehicles.
Vehicles
Recommended ILSAC GF–4 SAE 5W–20 Engine Oils
This oil has been set as the Lexus genuine engine oil, starting in February 2006 for the U.S. This (5w-20)oil is superior in terms of fuel economy, engine protection, and cold
starting performance.
TSB:
Vehicles
