Yes, the 51459 (iirc) is the biggest WIX in the 3/4-16 thread. There may be one slightly bigger. The 51773 is fractionally shorter.
Part Number: 51459
UPC Number: 765809514591
Principal Application: Bussing, Case, Caterpillar, Iveco, Massey-Ferguson, & Perkins Engines
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 7.010
Outer Diameter Top: 3.694
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 7-9
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=21/38
Burst Pressure-PSI: 310
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 25
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.834 2.462 0.200
Part Number: 51773
UPC Number: 765809517738
Principal Application: Ford Trucks, Massey-Ferguson Tractors, Oliver Tractors, VW Eurovan (93-95)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 6.982
Outer Diameter Top: 3.663
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 290
Nominal Micron Rating: 32
Gasket Diameters
Most engines go up to the relief limit at cold start. It's often a compromise between required operating visc and volume ..and our current limits of VI. Nothing new there. Assuming no outlandish volume is part of the operational variable, the most frequent situation where elevated PSID is seen is during cold start and during the relief event. The engine makes up the lion's share of the pressure development.
Anyway, it's hard to figure such a narrow bypass setting ..but it's there.
The use of the bigger filter should reduce any potential bypass event.
