My differential makes a loud whine only at 67-70mph. Throttling or braking out of that range promptly eliminates the noise.
The unit has been babied with conservative lubricant change intervals with Redline 75W90.
Some online sources say this indicative of ring and pinion wear ... although this is not singularly the end of the world. Is a ring and pinion overhaul the only solution to eliminate the noise? Could it be something else? Could something "heavy" like Redline Shockproof do the trick and silence this? A quality reman Jasper unit (2300$) would be over-kill and a ring-pinion overhaul would be some 6-7 hours of labor I have read.
Application GM 7.5inch 10-bolt rear, Auburn Limited Slip, 3.42, 188,000miles.
