Hopefully the small block chevy experts can chime in, obviously I have a small block chevy and I was wondering if the bypass valve is either in the engine block or is it in just the oil filter. Could I have a bypass valve in the engine block too, since I am sure oil filters come with a bypass valve that is like a spring.
If there is a bypass valve in the engine block, can this go bad, and are there any symptoms too look for, when I change my oil and I take off the oil filter it is full of oil.
