I noticed recently that the freehub on mountain bike is very quiet and does not make that ticking sound when coasting. The freehub does not spin smoothly like something is gummed up inside. I removed the freehub, flushed it with some Seafoam and it now spins much more freely and has the ticking sound again just like new.
What kind of lube is used to for the freehub? Searching around and some people use Phil's Tenacious oil or Tri Flow. Phil's Tenacious oil is kind of thick and sticky, not sure if its the right stuff. Thanks.
