Here is the scoop. I have front diff whine in my 06 RAV4 V6 that specifies WS ATF in it's transaxle. The whine is a known issue with no fix from Toyota. Some people on RAV4 forum fixed it by thicker fluid such as Mobil 1 ATF. Thus, I tried Redline D4 drain and refill at 30,000 miles. The car drives fine, but I noticed tiny metal shavings on the tranny dipstick after the change and driving just ~20 miles (and never before). I did a poor man's patch test by doing a card blotter test and examining the blot under my kid's Intel Digital Blue PC microscope (a toy, but very powerful, NASA used it on the martian meteorite study). Examples of particles here (I didn't count, but way more than 30-40 in one drop of ATF):
Magnification is 60 times, so the size of the shavings is 0.05-0.5 mm (rough estimate). They are steel (magnetic). I checked ATF in my other car and the WS fluid I drained from RAV4 by the same method and there are no particles whatsoever.
I'm trying to figure out what went wrong. Probably will drain back and flush with WS.
I consider these possibilities:
1. The Redline D4 was bad batch or counterfeit. Possible, but not likely as the bottles looked like they should and were sealed the way Redline oil is. However, I bought it on ebay from a Kia dealer at a big discount.
2. I should have tried Redline D6 rather than D4 as D6 is closer to WS in viscosity. Why would that cause gear wear?
3. Redline ATF caused some additive clash with WS and should not be mixed with WS.
4. Same as above, but acceptable after a complete flush of WS out of the system.
5. Initial break-in wear due to change in friction pattern (I doubt this).
Any ideas or experience with D4 ATF?
Thanks!
Thanks!
