Hi,
I found this here: http://www.widman.biz/uploads/Corvair_oil.pdf (page 19)
"You should not pre-fill the filter unless you do it from the outer ring holes. Any oil that goes into the center will reach the engine unfiltered (and there is no cleanliness standard for new oils)."
Does this make sense? I always pre-fill the oil filter when doing an oil change to avoid the engine running dry on first start. There are no outer ring holes on my filters (Volvo) so either I prefill them with unfiltered oil or I leave the filter empty.
What's the best solution?
