A couple of months ago, I replaced the struts/shocks on the PT Cruiser with Bilstein HDs. The rears were fine, but the front passenger side rattled way too much and made noise each time I turned the wheel.
Turned out I should've replaced the strut mounts at the same time. So I took it back apart and replaced those.
Much better, but still "squeaky". Turns out the control arm bushings were shot ( a common Chrysler problem).
Took it in to the shop today to get the bushings replaced with ENERGY polyurethane ones and get everything aligned properly.
What a difference! I can actually enjoy driving it now. No more squeaks or rattles and solid steering feedback! Feels the same, if not better, than when it rolled off the dealership lot.
