We have a 2008 Rabbit with the 2.5L engine.
Based on this comment..... "I am not sure if there are any used-oil analysis (UOA) results with Syntec in the 2.5-liter Rabbit, but everything I have read indicates that that engine is very easy on oil. It's not turbocharged, it does not run super-hot, and it has a relatively large sump capacity -- it is everything that the 1.8T and 2.0T engines are not, and those are engines where the 5k-mile OCI is recommended."
....I am wondering if Mobil 1 0w30 would be a good oil for this engine with 5k OCI's? The reason I ask is....with the recent M1 rebates, I have stocked up on 0w30. At the least, would the Ow30 be a good winter oil as opposed to the recommended 5w40....then I could pour in 5w40 for a summer fill?
What do you think?
What do you think?
