I've owned quite a few of the engines on that list- a 4.0 inline (as someone else pointed out, its an AMC design that Chrysler beefed up quite a bit over the years), a 3.5, and a 2.4, and a 4.7. Plus I've had all the others in rental cars at one time or another too. What you have represented there are 5 very different engine families, so really the only things in common are external:
1) AMC inline (2.5 and 4.0)
2) 60-degree belt-timed SOHC v6 (3.5, 4.0, and 3.2)
3) POS 2.7 (sorry to those who own them, but that's the only Chrysler engine I've ever actively disliked)
4) 3.7/4.7 90-degree SOHC
5) 2.0/2.4 SOHC and DOHC inline 4 with balance shafts
In the case of the 3.5 and 4.0 v6 (the two are identical apart from a difference in bore) the ribbed timing belt makes a slightly audible whine at certain RPM ranges. Same for the 2.4, plus it has its chain-driven geared-together balance shafts that *might* contribute some sound but I never hear them. All the others are chain timed so any timing chain whine will be more muffled, although the 2.7s chain system is notoriously loud because of its multiple snubbers and two secondary chains.
I can't hear ANY whine in that Grand Cherokee video (I don't know whether to be impressed at the guts or shocked at the stupidity of taking a GC to >100 mph, but that's one healthy modified 4.0!), and the only "whine" I can hear on my own 4.0 is from the serpentine belt and PS pump. The 4.0 inline was built in such huge numbers and for so long that it comes in quite a few slightly different configurations that make different sounds. The serpentine belt is differently routed on a Cherokee vs. a Wrangler vs. a Grand Cherokee, and the older 4.0s didn't have the main bearing cap girdle and a few other goodies that Chrysler added over the years to stiffen the assembly, so they sound subtly different too.
FWIW, my wife's old 3.5 had a fairly noisy PS pump too- it was a GM/Saginaw pump. Older (70s and earlier) Mopars used Federal PS pumps that were very quiet, and later Mopars seem to use ZF pumps, and they're also a little quieter than the Saginaws. The Saginaws with a divorced reservoir like the 3.5-equipped vehicles have are even louder because the integral reservoir on the others acts as a sound-deadener with all that fluid right around the pump itself. Never had a lick of trouble from a Saginaw, but they have a very characteristic sound- you can hear it on many GM cars too.
Originally Posted By: rudolphna
Curiousity finally got the better of me. Why does it seem that all, or nearly all, chrysler engines have a whine noise at WOT or higher RPM. It seems characteristic to most chrysler engines. Anyone knowledgable on this?
Here are some videos that showcase the whine noise.
4.0L Inline 6- Mostly audible above 4krpm
http://www.youtube.com/watch?v=bZjrkXa7u04&feature=channel_page
4.0 V6- Clearly audible through most of the RPM range.
http://www.youtube.com/watch?v=gIIkbk6sEqs
2.7L V60 Audible above 3krpm
http://www.youtube.com/watch?v=a7lpfE02b5g&feature=channel
2.4L Inline 4- Audible above 3krpm
http://www.youtube.com/watch?v=2gZ7WeJcEFA&feature=channel_page
3.5L V6- Audible above 3.5krpm
http://www.youtube.com/watch?v=zQSGIVbo-oo&feature=channel_page
4.7L V8- Audible above 4.5krpm
http://www.youtube.com/watch?v=J6eoKJfqlFM&feature=related
