So I found a screw in my tire, and finding a place that was willing to patch it (at least until I could replace it) was an ordeal.
Now I have a 2004 Subaru Impreza WRX with one patched tire that has decent tread everywhere except the inside shoulder. I rode on it flat for days without realizing it, and I think the negative camber had something to do with that shoulder wearing quickly. I'm keeping an eye on it and will probably replace it in a few weeks.
I actually have decent tread left on the remainder of the tires. It's 6/32"-7/32" on the remaining Bridgestone RE960AS tires, which came from the factory with 11/32" tread depth. I've gotten 26K miles on this set, so I'm hoping that I can push 40K at least before getting new tires. I don't particularly want to get a new set now, and the shop I went to said that their distributor could shave the tires (maybe to 7/32") which should be acceptable for a Subaru.
Anyone tried this on an AWD car? I'm thinking that the shaving process probably won't trim it exactly like regular wear would achieve, but it would be close enough to reduce torque binding on the diffs. I needed to stop riding on the compact spare (on the rear). I was getting this whooshing sound coming from the back about a half second after I took off, and I wasn't sure if it was the center diff or the rear LSD. I tried keeping the speed down by taking surface streets to work, but the noise was really annoying.
