Had "check engine- D=11" light go off coming home on Sunday night. Took it to the dealer on Wed. The Van has 30K on it.
After waiting about an hour the service advisor informed me that the cause was the code: 3497, Valve pause system system stuck off.
He said that there was no oil on the dipstick.
I told him that I change the oil about 3500 miles ago. I was invited into the service area and watch the mechanic drain 1 quart from the engine. 1 quart! The filter on these is very small, so add another 1/2 quart, with a little bit more in the pan.
There was no leaks. My garage floor is white and clean.
I told them to change the oil. and reset the check engine light. I now have to pay for the diagnostic check, 65.00, no warranty service for the 1 quart guy.
I had a meeting with the Service manager and laid out 3 possible scenarios .
1. I went to Autozone bought 1 quart of snth blend and a filter and went home drained the oil and installed a new filer adding 1 quart.
2. I went to AZ and bought 5 quarts + filter and only put one quart in leaving 4 on the shelf.
3. Bought the proper amount and did a complete oil change.
Now there is no way that I just put one quart in that van when I did the change. I explained that I just restocked my shelf in my garage with 5 quarts and a filter and was preparing to do a change this week. There is not 4 quarts from the past change sitting there. I KNOW FOR A FACT that I put the 4.5 quarts in the car and checked the level before my wife left for FL. a couple of months ago. There is no possible error on my part.
They still had this look on their faces that the Van does not have a problem and the error was mine. That is insane.
I have spoken to a Honda ace and he said that these engines do not burn oil with blue smoke and noticeable smells as engines in the past have done. I asked these guys to put a seal on the plug and the filter to make the next draining in their shop without suspicion. They could not do that.
What do you guys think here? The oil pressure lights never came on. The Check engine light just appeared on Sunday.
I can't stand having anyone think that I would run an 08 Honda Odyssey on 1 quart during hot NC summer. But that is their conclusion.
