Originally Posted By: Audi Junkie
When I saw there was a big Motorcraft "S" filter (310?) that fit the VW/Audis but had a lower bypass, it got me thinking what would be the effect of running it. How I see it is that the lower BP could be beneficial in a high-rpm situation, like track use. Instead of filtering 100% ofthe oil every pass, which is totally unnecessary, the BP could pop open and pass a large percent of the oil flow, while filtering on and off at other times.
I know I'm not qualified to make the call, but I know people have used this type of set-up by accident, without any consequence.
It would also mean potentially sending a big load of crud off the dirty side of the filter on into the engine.
I thought there were some Subaru turbo engine issues with debris clogging up some kind of orifice downstream of the filter and thereby choking some needed oil flow to the turbo or something else critical. Could be caused by the bypass valve opening and sending crud into the engine.
Instead, use a filter with the higher specified (by Subaru) bypass setting ... that would ensure all the oil is getting filtered, even at high RPM use like at the track.
