First off, I might of posted this sometime in the past. Just to be sure I did a search and no results came up after several attemps. So either the search is acting funky again or I didn't post it ever.
Anyway, Tommorow I'm changing the oil on our 31K mile '97 Tracker. The Tracker sees alot of city stuff, short trip driving. Once in a while it is taken out on the highway for about 10 miles or so but it never goes on long road trips due lack of cruise control and it's geared way to low(numerically higher, 3800RPM@70mph in 5th gear) I'm going with M1 5w30, either EP or just regular M1 synthetic and a Bosch filter(or would a Federated filter be better?) The Tracker is on it's Auto-rx stage(not rinse phase) If some of you may have a better recommendation, I'm open. Thanks,,,,AR
