Wow, John.. you sure HLAs are that bad? They keep engines quiet, unless you sludge up your engine. I really wanted to convert to SLA bucket lifters, but a friend of mine with the same motor has cams, springs and uses stock HLAs and his redline is 11.5K RPM. That's not bad for HLA! He runs 11's all day, all motor, and most of that engine is stock. How many 3+year old Honda have a supremely quiet valvetrain? Few and far between because people really don't buy Hondas to crack open the valve cover every 36K you know? It's no problem for you and I, but the average Jackson that just wants to gas, go and do basic maints, wont think once about it. They don't buy Toyotas to have to measure lash, test fit a new shim, re-install cams and re-measure lash only to repeat that 16 times which explains why the valvetrain on every 2.0/2.2 Toyota all sound terrible. Newer style mechanical bucket lifters seems to be more durable to live up to their "lifetime adjusted" status, as the good ones all have tapered base circles which pull oil onto the bucket surface with every revolution. IMO mechanical rockers/finger followers are the worst as the cam pads and the adjustment screw have a tiny fraction of the wear surface of a rotating bucket lifter. Ironically, a large percentage of people have neglected oil changes, get HLA tick and auto manufacturers have responded by converting to SLA to mask the problem! Try changing your oil
