Originally Posted By: Onmo'Eegusee
He makes some
assumptions in his presentation. Filtering ability really stuck out.
Also is apparently not aware the ADBV on a E-Core also acts as bypass, if needed.Calls a silicone ADBV jelly like. Well I would hopw so, maybe it will seal when I want it to.
Good points! So his conclusion that ST has NO bypass is FALSE. Also, clear to me that he doesn't understand that a the "red gasket" to which he refers is a silicone adbv used in higher end oil filters. And, that soft and pliable adbv is a good thing. So it appears as though in his case it's true what happens when you a$s-u-me. Not
me here though.
Originally Posted By: SuperBusa
This what he said about the PureONE:
Filtering ability: below average.
Antidrainback: below average
Bypass: below average
Filtering ability below average? ... well, at 98%+ I'd say that's not "below average". And just how does he conclude if a bypass valve or ADBV is above, below or just "average". Kind of squirrely I'd say.
True that. Did DoctorD run spec tests on filtration, adbv function ability and bypass psi? If so where are the test procedures and results published? If not, it's totally subjective. So, like much else here, it's his opinion.
Originally Posted By: daman
That guy doesn't know [censored] does he? love these wana be "pro" oil filter analyzers.
+1, on not knowing [censored] from shinola.
Wannabe oil filter analyst would be an apt description of DoctorDolt, IMO.
I prefer the linked dissected filter study posted here recently. It has a nice spreadsheet which includes actual objective
factual information and less editorial comment.
http://www.300cforums.com/forums/general-discussion/31190-oil-filters-dissected.html
