Originally Posted By: Buffman
Originally Posted By: Onmo'Eegusee
Yes, it is. Its running over 5000 at the 108mph limiter. (btw, which I do not recommend testing, the steering is very light, with the pump running so fast.)
That's the only thing i hate about my wife's 01 is the 3 spd. I give it credit though. it can still turn almost 27mpg with it. With 120K on the clock, I've been tempted to install a new OEM 02 to see if mpg will improve.
I got her AC going again a few weeks ago after it hadn't been working for over a year. turns out
the shaft seal in the compressor was bad. Leak dye didn't show up until after refilling it two times. Luckily I found it before digging into the dash to do the Evaporator. I learned my lesson about the reman AC comp, and found a Autozone that had a new OEM Delphi in stock. The reman (wanted new anyways) Ready-Aire only lasted 15 minutes then it blew the shaft seal. It didn't sound right from the get go after filling it with oil, but I had my fingers crossed.
It blows ice trucking cold now with new orifice tube, condenser, drier, and Comp
thats exactly what what happened to my 97 Cavalier compressor.The shaft seal,I wonder if their were bad seals or something?
