Hello all,
It's time to change the oil on my 2007 Honda Rancher AT (TRX400FA). I was looking in the manual and it recommends 10w30 oil. At the local Honda stealership, the oil is Honda GN4 @ around 8$ per quart. I think that is pretty steep for dino oil.
My question to everyone is, what other oils can I use? I know it can't be "energy conserving" oils, or any oil that is not rated JASO-MA and API-SL (I think?). I would like to use a good synthetic, but I am not sure what I can use thats JASO-MA certified. I have no problems sticking with dino oil either.
Any ideas? Keep in mind this is the Hondamatic Automatic trans and uses engine oil so it must be somewhat critical to use the right stuff. What does everyone suggest that will work with this engine/trans setup?
Thanks...
Thanks...
