Latest oil sample from Goughs SOS Cat
1999 Nissan with total mileage 180,030 kms and 10 months on oil.
Make up oil 3 litres due to TP change on Motorguard bypass at 5,000 km intervals.
First column latest results,2nd column previous result with total of 20500 km.
Cu 4 5
Fe 15 14
Cr 2 2
Pb 3 3
Al 2 2
Si 1 2
Na 3 2
Sn 2 0
Mg 9 10
Zn 1237 1193
Ca 3496 3424
P 993 1019
B 2 4
Ag 0 1
K 1 0
Water 26.0 18.8
NIT 10 9
GLY 4 3
Soot 33 29
SUL 46 40
OXI 45 43
V40 86.8 87.8
PQ - 7
Other wear metal values zero.
Comments
Infra-red levels are increasing-Wear levels appear acceptable-We recommend to resample at 5,000 km.
Rang the lab to ask what they were concerned about.The Sulphation,Oxidation and Soot were trending quite high and shouldnt be allowed to increase much further.Their normal caution levels are 34 for Sul and Oxi and 30 for soot.They said this very much depends on the engine manufacturer,but in the Nissans case no such data is available.If the Sulphation gets too high the oil will become acidic and may attack some metals.They also mentioned the water,a reading of 35 would equate to 0.5% on their scale.I asked about the Glycol at 4 to which he stated this quite often shows up when synthetic lubes are used.
My question to you folks is should I change out now or continue for another 5,000kms?I should add,this vehicle does a lot of short trips,work and back only takes 8 min each way.
Cu 4 5
Fe 15 14
Cr 2 2
Pb 3 3
Al 2 2
Si 1 2
Na 3 2
Sn 2 0
Mg 9 10
Zn 1237 1193
Ca 3496 3424
P 993 1019
B 2 4
Ag 0 1
K 1 0
Water 26.0 18.8
NIT 10 9
GLY 4 3
Soot 33 29
SUL 46 40
OXI 45 43
V40 86.8 87.8
PQ - 7
Comments
